Need Help with Closing Holes on my Model
Niko018_
Message 1 of 17
Niko018_
Hello, I have a problem. I want to close the holes on my model so that there are normal surfaces so that the shape of the model is retained but the holes are closed.
Replies (16)
Message 2 of 17
TheCADWhisperer
@Niko018_ wrote:
... so that there are normal surfaces so that the shape of the model is retained ...
@Niko018_
The problem is that there are no "normal surfaces defining the shape of the model" in the geometry.
All you have is straight lines and faceted triangular planar surfaces.  No curves.  Not even one.
Maybe somebody can do something with it.
Message 3 of 17
Niko018_
First of all, thanks. I'm not very familiar with the program, but I cut out the model components the way I needed them. Now I just need the "base model" to continue working with it. And for that, I'd have to close the doors and other things as well.
Message 4 of 17
TheCADWhisperer
@Niko018_
No file Attached?
Message 5 of 17
Niko018_
Ok i will send it
Message 6 of 17
TrippyLighting
Fusion is completely the wrong software to achieve what you are looking for!
Continued modeling work on this particular triangulated mesh model is better done in Blender, which works with mesh/polygon models natively. It'll be a lot of work!
The model contains an enormous amount (4353!) of duplicate vertices!
Message 7 of 17
Niko018_
Ok, can you tell me what to do next or send me a yt video so I can continue working on my project. That would really help me
Message 8 of 17
TrippyLighting
Can you post the original, unmodified model, or was the .stl file you share all you have?
Message 9 of 17
Niko018_
That’s all i have
Message 10 of 17
TrippyLighting
I've taken a closer look at the mesh and I believe this is futile. There is so much more that would have to be fixed on this mesh beyond "filling holes" .
I am not aware of any videos specifically aimed at fixing such things, but there is an enormous amount of Blender tutorials on YouTube covering every aspect of it.
Also, I am convinced you'll find a better, more complete model of this helicopter online.
Message 11 of 17
Niko018_
Ok thanks, I have a complete version of the helicopter but I cutted out the things I need separate. My problem is that I need the sides smooth and plain. And tha is why I need so close the side holes and the top.
Message 12 of 17
TrippyLighting
And why did you not share that complete model?
Message 13 of 17
Niko018_
First of all, because the original model is much too small and I adjusted it to the right size. And because I need exactly what I sent only with closed pages.
Message 14 of 17
TrippyLighting
Let me be clear. Unless you share the original model, my help stops here!
Message 15 of 17
Niko018_
Ok sorry. I attach the model right here.
Message 16 of 17
TrippyLighting
Oh Boy!
I've created a screencast using the model you originally posted. I stand by what I said: you are better off finding a better model of the same object than trying to fix this triangulated garbage. However, if you must use this model, the video provides a brief outline of what it entails.
https://youtu.be/sKh8tfNnvoA?si=VEyHJ4rL-9yKvy5_
Message 17 of 17
Niko018_
Thank you. That video helped me a lot.
