- Mute
- Permalink
- Report
I am having trouble figuring out how to get a boss in the lid of attached image to match onto sloped surface.
I want to have a counter bore hole so a bolt can be insert at top of box(with head recessed around 2.5mm) and hread to come out through bottom to attach to the enclosure base.
I used the base of lid as reference but when I extrude to far, the boss come out through top and if not far enough I get a gap like below. I am not sure if there is a command to get it to meld with the slope or I should somehow start the hole on the slope from top and use standard counter bore hole?
