Need help understanding Sheet metal flange angles
- Mute
- Permalink
- Report
Hody folks,
I am creating a Sheetmetal part where the vertical part tapers to one end and is also kicked in (To the left) from the starting point. I am trying to place a 0.75" flange on the upper edge to facilitate attaching a cover to it. The problem is that when I bend the flange to 90 degree angle. the upper edges will not support the cover because they slope downward towards the center. I can fudge the angle to achieve the required result but would only be guessing. Can you guys help me understand why the 90 degree upper flange is not parallel with the lower 90 degree bend. Any help calculating the correct angel would also be appreciated. I have included screen shots illustrating my problem.
Thanks in advance for any insight on this
