Need help on how I tackle this part
michael.arnold1008
Message 1 of 11
michael.arnold1008
Hi Guys, I’m in need of a fast bit of help and am hoping someone can shed some light on how I tackle drawing the part I’m trying to create.
i need to draw an iron basket used on ornamental ironwork such as gates and railings. As in attached picture.
I cant for the life of me work out how to do the spiral. It’s made from 4 10mm square bars. 90mm in total length.
any ideas would be greatly appreciated!!!
Arnie
Replies (10)
Message 2 of 11
TheCADWhisperer
Intersection between surfaces and then Sweep and Pattern.
File>Export and then Attach your *.f3d attempt here.
Message 3 of 11
michael.arnold1008
thank you for such a swift reply. Unfortunately I don’t really have anything to upload, I keep trying things to make it work but just don’t know how. I’ve tried things such as loft between two planes but I can’t get any spiral onto it. I’ve only been using fusion for a month or so now, tbh I can’t even get it to work on Turbocad.
Message 4 of 11
TheCADWhisperer
This same problem is all over YouTube.
Start with a Revolved Surface of an appropriate open profile something like this.
Then Attach your *.f3d file here for next step.
Message 5 of 11
michael.arnold1008
Okay thank you, Something like this?
Message 6 of 11
TheCADWhisperer
I would have done the axis of revolution and the two horizontal lines as Construction.
I would have fully defined the arcs (no blue curves).
Then I would Sweep a line as a helical surface.
Message 7 of 11
TheCADWhisperer
Next you will find the Projected Intersection to create Sweep Path for square sketch or you might be able to use Pipe.
There is a little bit more to it to get the transition to straight vertical, but this should keep you busy for a while.
Message 8 of 11
michael.arnold1008
thank you, im still stuck trying to sweep a line, it wont let me select a line to sweep with?
Message 9 of 11
michael.arnold1008
I have got a bit lost and ended up like this..
Message 10 of 11
laughingcreek
Here's another approach.  I just eyeballed the 3d spline, but it could be tamed with some will placed planes and sketches .
Message 11 of 11
michael.arnold1008
Eyeballed?! Smiley LOL fair play its pretty spot on thank you. I will study how you did it. Thank you
I'm still trying to work out the helical spiral way also
