Need help making a shower base
wquinton
Message 1 of 22
wquinton
Were looking at manufacturing shower bases on our cnc and having trouble design this in fusion 360 Were trying to slope to the drain. We need outside edge to remain the designated height and slope to a hole that is on the far right
Replies (21)
Message 21 of 22
houdi84
Thanks for the feedback. I'd think it was because I'd turned off the body so that I could select the circle in the floor - I thought that's what you did in the screencast so followed suit.
But the main thing is I can reliably recreate it now which is fabulous and has allowed me to continue with the project.
Out of interest I'm building a small enclosure for a home built electronic circuit to measure the temperature of a garden pond's water using a probe, and to transmit it back using an ESP32 to Home Assistant. The sloping floor is to allow the probe to connect to the circuit but also to encourage any condensation which may occur within to vacate the container.
Progress is slow but sure and satisfying - thanks again!
Message 22 of 22
jlarsonLP454
Ah, that makes sense. Yes, I turn off the body visibility so I can see to select the sketch, but then turn it back on again so the tool actually works - kind of an annoying Fusion quirk.
Hope your project turns out well!
