Need help installing logo onto surface
Hi Guys ,
am trying to put a logo onto the right hand tab of this component , and then use the extrude comand to cut it out , can that be done , and if so what file format do i need to import the logo.
Malcolm
HughesTooling
DXF of DWG will work, SVG will work as well but you might need to play around with the scale at import. You might find this thread useful because it's easier to edit a sketch pasted into your design rather than inserting a DXF or DWG. Just upload the DXF\DWG open from the data panel then follow the instruction on how to paste.
Mark
Mark Hughes
Owner, Hughes Tooling
