need help extruding from sketch
mark
Message 1 of 25
mark
I have had a problem numerous times and I've finally isolated it into a project to show.  see here: https://a360.co/3hlnfkJ  This is a sketch consisting of one curve along a bezier and one line closing it to make a closed curve.  I cannot get the interior selected to do an extrude.  Can someone help please?
Replies (24)
Message 21 of 25
mark
Thanks everyone for putting time into helping me ...
My current workaround is to duplicate the tab first
Good suggestion.  Doing that now.
reassembled (badly)
Yes.  At the time I created that object I was either drunk (kidding), or in a rush.  It is an example of rapidly hacking and hewing until I got something that looked good at a high altitude.  I should point out that while this is for production, it uses desktop 3d printing and any feature smaller that 0.1 mm can be ignored.  I have daydreamed of witing a F360 extension that just dissolves all features smaller than a threshold.  Errors pointed out above would disappear.  I am mostly a software programmer which probably explains my bad designs.
hold the left mouse button down
Aha.  Very useful.  I have now been able to accomplish the original extruding task.  Between projects I should take a week off and go through *all* the tutorials.
what operation is it you where wanting to perform on the edge of that part?
So now we start the third topic of this thread.  I am trying to "shrink" the edge of the object to compensate for filament expanding sideways.  The mating hole for this part has already been produced and this part is too large.  I can't use scaling since I need a fixed distance (0.2 mm) on all parts of the edge.  My approach was to sweep a rectangle around the edge and subtract the resulting body from the part.  I ran into a brick wall when the swept body was too damaged to be used.  This is the Body1501 I referred to earlier.  Now I should be able to use the spline-copied edge for sweeping.
Dare I hope that there is some simple way to shrink an edge that I have missed?  Offset-face was an obvious candidate that didn't work for me.
Message 22 of 25
laughingcreek
offset faces would work with clean geometry.
-in the attached I created a clean sketch fairly close to the original profile (I guess you deleted all your previous sketches for some reason? might have made this a little easier), but offset by 1mm. why 1 mm?  easy number, landed in a clear area, no other particular reason.  made sure everything was tangnent and that it didn't contain any funkyness.
-extruded that to slice off the outer parameter.  mirrored it so at least the outside of the part is symmetrical,  and then offset the faces back to achieve the desired offset of .2mm
screen cast of doing the offset.  here I ended on .5 b/c I forgot how much it was suppose to be, in the attached I used .8 (1mm-.8mm=.2mm).  also had the timeline turned on so you can see what I did.  (or in case you need a different offset later)
Message 23 of 25
mark
Thanks.
My mistake.  I thought I was in the real project.
Screen casts haven't worked for me for some time.  I get an endless spinning wheel or an error saying something about there being a server or network error.  I'm using latest chrome on latest windows with healthy network.
I will study the timeline.
Message 24 of 25
mark
FWIW:  Turning all extensions off fixed my problem and I can now view the screencast.
Message 25 of 25
mark
Wow.  Thanks.  I like the solution and the results and the free work.  I have lots of other broken objects lying around.  How much time do you have?
