Basically I want to connect these 3 sketches to create a 3 head shape. I've tried using the Loft feature but every time I try it, It creates a straight path to each face. Can anyone help? You can kind of see what it's supposed to look like in the picture and I included my file. Thank you
Solved by Drewpan. Go to Solution.
I have had a bit of a look at this but parametric modelling software is not really what you want to model it. I think
Blender or one of the other packages might be better. Parametric software is exactly what you want if you want
precision and know the mathematics of the curves involved but this is form sculpting and it is very different. It isn't
impossible to do in fusion just not easy.
Cheers
Andrew
