Mysterious joint failure
etfrench
Mentor Mentor
etfrench
Creating a joint between an external and an internal component is failing.  The error message is not particularly helpful.
There are no existing joints between these components, so how can there be a conflict?
ETFrench
Pradipio
Autodesk Support
Autodesk Support
Hi @etfrench ,
Thanks for posting to the Fusion 360 Forum.
Yes, this is a mysterious joint failure, Let me investigate this and will get back to you.
Once again thanks for sharing the issue with us.
THANKS
Pradip Mistry
”Community
Pradipio
Autodesk Support
Autodesk Support
Hi @etfrench ,
I did some workaround and that fix the issue.
There are some joints from the imported parts like bolts and bearings, I removed all the joints and re-joints manually which fixes the issue.
I made a video screen recording for the same please check.
THANKS
Pradip Mistry
”Community
Pradipio
Autodesk Support
Autodesk Support
Hi @etfrench ,
here is the Fusion file for your reference.
https://a360.co/3q3K069
THANKS
Pradip Mistry
”Community
etfrench
I've already redone the file 😁.  I was just reporting it for the bug.
ETFrench
