My projects
My projects
kevinPHCRA
Message 1 of 11
My projects
kevinPHCRA
No picktures on my project
Replies (10)
Message 2 of 11
Hii @kevinPHCRA
Greeting for the day.
Thanks for using Autodesk Forums, But you should use this forums for solving your problem.
  Best Regards
    Anil Kumar
(Student Expert)
Message 3 of 11
kevinPHCRA
I am trying to solve my problem but i cant attatch a picture
Hope this works and answers you request for a picture of my problem.
Many thanks kev
Message 4 of 11
TrippyLighting
You've tried this button ?
Message 5 of 11
kevin
As far as etiquette goes.
If you are having trouble solving something that you also believee maynot be in the API where do you post it?
Under API or Problems?
Message 6 of 11
TrippyLighting
I'd post it in the support forum.
If it is determined that it might be better in another forum section, the forum admins can always move the thread there.
Message 7 of 11
kevinPHCRA
I hope this comes to you all as i have no pictures and when i double click it flips to the build plate but no design come to light ???
Message 8 of 11
kevin
I had some of the same problems and had to go into my NVidia control panel and explicitly select my Quadro card over integrated graphics
Does the mouse still change depending on which icon its hovering over even when you can't see?
Thats a dead give a way its covered with a blank mask.
Message 9 of 11
kevinPHCRA
Sorry my friend i have no idea what you mean by .......card as im no pc
expert.
When i hover over the box where the picture use to be it is blank but the
title of the design is shown if that helps.
Many thanks kev
Message 10 of 11
TrippyLighting
Your screenshot is from 123D design. This is the Fusion 360 Forum, so help might be a little slower than usual.
Message 11 of 11
kevin
#1 - Do you have multiple video cards? Cuz it could be using the wrong GPU
#2 - Has it been long enough for those projects to render a thumbnail image?
#3 - Could it be that you don't have broadband?
