My profile
My profile
My profile
Hi all,
From the main Fusion 360 start screen, when entering my profile, it switches to A360 profile.
Is this normal? as I dont have the old A360.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Are you referring to when you click on your name in the top right corner and then click "My Profile"? If so, then this will send you to the A360 website where you can view your projects and data. If this is not the case, do you mind creating a screencast of the issue so that I can understand a little bit better what is going on? You can download screencast at:
https://screencast.autodesk.com/
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
Yes that is what I was looking at.
I thought My Profile had gone to the wrong area, as I have Fusion 360 not A360.
I suppose Fusion 360 is the newer version of A360, and it will be changed or restyled later. Smiley Happy
Thanks for clearing it up.
Lee
James.Youmatz
Autodesk Support
Autodesk Support
Glad I was able to help! Let me just help clear some things up though. Since Fusion 360 is a cloud based software, it saves the files you create to your A360 account which can be accessed multiple ways including at www.myhub.autodesk.com or by clicking "My Profile" as you have found. A360 is kind of a mix between Google Drive and
Facebook. It is a collaboration tool where you can access your data as well as include others in your project and share your ideas and information. You can also see the projects/data you create directly in Fusion 360 (as I'm sure you've already noticed) by opening the Data Panel.
Hopefully this helped clear that up a little bit and I'm glad I could be of assistance!
James Youmatz
