Multiple spring passes for 2D contour
Is there any way to do more than one repeat of a pass?  I would like to be able to select multiple spring passes on 2D contours.  Especially for critical hole dimensions.
jhackney1972
The number of finishing passes on a 2D contour can as many as you would like.  You use the word "spring" passes, maybe you are talking about something else, if so clarify.
John Hackney, Retired
rhdfmail
Springpass = one extra pass at final depth to cleanup restmaterial from tool-deflection
4 finishingpasses will start 4 x finish-stepover out and do 4 passes.
Probably it will solve the problem with a very small stepover
Marco.Takx
Hi @Anonymous,
If you want one extra repeat pass you can check this option on the Passes tab.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
