Multiple Questions Please Suggest how to solve these Problem
I am design engineer I used solid woks In past  and now i am using Audodesk fusion 360 from last 4 month. I am finding serious Problem and frustrated while using it . These are different situation Below Please Suggest me Solution of these problem:
Situation One:
I Made 80 drawing of different parts I want to print these drawing in one go .
What I am doing
Now I export these drawing into pdf form and Print them taking 3 hours for printing these drawing.
Situation Two
I want to export 2d drawing into DWG format but after exporting  no drawing lines are available.
What I am doing
Now I export the 3D Model into IGES . Open in other software Make 2D Drawing Export in DWG Format Taking 1/2 hr for One  Model If i have 80 part to convert Please calculate .
Situation Three
I made a drawing of 3d model and saved it. Next Day i forget whether i made  drawing of same model or Not. I dont have any option to check drawing of model is made or not.
What I am doing
Now I export the same drawing multiple time causing duplicate drawing Time Wastage.
HughesTooling
@cmiller66 or @TimeraAutodesk Can you help with this?
Mark
PS this is the wrong forum I've asked for the thread to be moved to the design forum.
Mark Hughes
Owner, Hughes Tooling
TimeraAutodesk
Hi @Anonymous, thanks for posting your questions here. @HughesTooling - thanks for seeing this and looping us in!
For Situation #1 - are all of these drawings you're trying to export in 1 drawing set (using multi-pages), or are these individual drawing files?
For Situation #2 - @cmiller66 can dig in here to help you out.
For Situation #3 - You can always see if you have drawings already created for a Fusion 360 design by going to the File menu > Related Data. Any existing drawings will show up in the list, and you can click on them to open the drawing. I hope that's helpful!
Best,
Timera
Situation #1 - These all are individual drawings.
For Problem #1:
Are your drawings PDF files?
For my PDFs I hit *Combine files into PDF' in Adobe Acrobat. This allows to choose all files at once and merge them into one single pdf. And then just hit 'Print'.
If you don't have Acrobat capability to combine files, do a search for some PDF merging program that could provide the same result.
Good luck.
It is not possible when i  click on 3d model or in model tree it show the related drawing of that part .It will be much more easier for all users.
