I'm coming to Fusion 360 from AutoCAD. In AutoCAD I can make visible dimension labels for, say, the side of a rectangle. It's not a constraint, the length can still be changed, and if done correctly the dimension will automatically update.
Is there any similar feature in F360? I have a drawing that I want to share with a customer, and I want to show them that the dimensions they specified are in place. My customer does not know CAD at all and will be using the browser viewer, they won't be able to measure the drawing themselves (if that feature even exists in the browser viewer).
The dimensions I'm concerned about are the height between two bodies, which do not share a common sketch, so sketch dimensions won't work.
Thanks for any advice.
