Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
multiple extrudes
5 REPLIES 5
575 Views, 5 Replies
multiple extrudes
Hello, very happy this forum exist!!! I'm using fusion since a cupple of months ago, it's great. Question: how can i extrude a pattern on all sides exept the bottom, so on the back, 2 sides and top? Also on the fillets? Is it possible?
 Thannks to all.
5 REPLIES 5
neljoshua
@Anonymous,
I am not quite sure what you mean.  Do you want like a texture on all sides?  The same thing extruded from each face?  Something else?
More information would be helpful.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
in reply to: neljoshua
Hi, thanks. I mean that I would like to extrude (negative so I'll have a
solc on the surface) a pattern on all the surface, like multiple triangles
or something like that, so the pattern has a fluent flow on all sides.
Like, if I'd like to do it on a round surface, I extrude something on the surface and then I moltiply it using the rounded multiplier. (hope you have understood..., my english is no so good..)
SaeedHamza
Using a single pattern for all of the faces can't be done, that's why you will need t patterns at least to get this to work
One pattern for the sides, and one for both, top and bottom
Here is a screencast explaining what I mean
I hope it helps
Regards
in reply to: SaeedHamza
Thank you very much  🙂  🙂
Technology Administrators
