Multiple contours - Help request
AndrewVanis
Message 1 of 23
AndrewVanis
Where is a good starting place to learn how to mimic these compound curves in the attached image and surfaces and the tools and processes to do so?
Objective is to create a nesting shape to cradle the neck if this wrench.
I am using parametric design for the various sizes so if a parametric approach was feasible it would be great
TIA
Replies (22)
Message 21 of 23
TrippyLighting
This doesn't require ant more modeling skill than you already have 😕
Just as you lift the tool slightly to get it out of the holder, use the move tool to move it up slightly, and the use solid sweep.
Message 22 of 23
TheCADWhisperer
@AndrewVanis wrote:
...  and then swipe down to recess the head?
@AndrewVanis
See Attached example...
Adjust technique as needed.
Message 23 of 23
AndrewVanis
@AndrewVanis
THANKS!
Exactly what I was envisioning.
@AndrewVanis wrote:
...- imagine the wrench ..(being hot and being pulled into that slot melting the plastic to conform to the radii)
@AndrewVanis
Let's start by modeling the wrench end.
Now I just have to learn how to make this for my actual wrench form.  Walking through the steps in your and @TrippyLighting shared models has been EXTREMELY helpful so Thank You!
