Moving stuff makes it dissapear
Hey Guys,
I was trying to move some components and I noticed that weird stuff started to happen as you can see in the screencast. What is happening here and what am I doing wrong?
neljoshua
@Anonymous,
If you share your model, I can take a look.
I am not certain if this is causing your problem, but there are quite a few warnings in your timeline.  I suggest correcting them; it may help.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Thanks for the response, but I've found the problem. Apparently, I shouldn't make rigid groups before the model is done after I removed it, it worked fine.
Those errors are because I extruded from an existing CAD file, and removing the original part afterwards.
neljoshua
@Anonymous,
Glad to hear you got it solved.
__
