I am laying out plumbing under a concrete slab. My main view is on sheet 1 which is the top view looking down on the slab with the plumbing exposed in the concrete slab. I would like to take section views through the slab to show grades of the plumbing lines under the concrete slab. So my method is to identify the cut on the main view but show the section view on the subsequent sheets, one cut per sheet. How do I move the section view from the sheet where it is created to a follow-up sheet?
Moving a section view from the sheet where the view is taken to another sheet is not support in Fusion 360, at least not yet.
John Hackney, Retired
@Anonymous wrote:
I guess if I were to pull this off, I would put the main view in a small scale on the sheet, make the section cut and then scale the section view large enough to read.
You can have the main view off the sheet, no need to have it at a smaller scale.
Mark
Mark Hughes
Owner, Hughes Tooling
Something like this. For a PDF you will not know the main view is there, for a DXF\DWG it will be there just not on the sheet.
Mark
Mark Hughes
Is this still not an option?
How can this be escalated to be included? This would seem to be a fairly obvious requirement.
