Moving parts or assembly's between branches.
m.van.hameren
m.van.hameren
Okay, I've made some mistake's in the filesystem when I started with Fusion 360 which gives me troubles now.
I made two projects, let's call them A1 and A2.
In project A1 I have two branches: B1 = Master(green circle)
                                                             B2 (red circle)
In Branch B2 I've got two maps, in each map there are parts and assembly files.
I want to move the two maps from B2 to A2 but that does not seem possible, because branch B2 is not visable in the on-line tree.
How can this be done?
Grtz. Mark.
I assume you are referring to projects in your data panel. The sub-folders can be moved by right-clicking the file and selecting either "move" or "copy".
Kelly
m.van.hameren
Nope, sorry, that's to easy.
I figured that out, but does not work like that.
Thats when you move in the same branch, I want to move to another branche as explained in the opening post.
Thanks anyways.
lichtzeichenanlage
Are branches still supported? IMHO the beta test has ended a year ago (or so).
