Moving objects
Moving objects
Moving objects
My project will have three pieces.  After designing the first piece, I realized perhaps I was supposed design it in a component space instead.  Is there a way "move" or "copy/paste" the piece into a component space?  There is a screenshot of my project in the attachment.
(This is my first project.)
You can copy an existing body into a component. See screencast (might take a few minutes for it to process after I uploaded it) and hope that helps.
SaeedHamza
I wouldn't call it a component workspace actually, it's more like a small browser inside of a big browser, with it's own origin, sketches, bodies, etc ...
So you can simply right click the top of the browser and create a new empty component, then hold-drag the body to the component ( all this happens inside of the browser )
or if you want you can also copy the body and then activate the component from the browser then click paste
Regards
Saeed Hamza
Thanks to Wkwok & SaeedHamza for introducing me to many new concepts!
TrippyLighting
You should probably review Fusion 360 R.U.L.E #1.
Read the entire thread and view @Aaron.Magnin's great little vid on how to put a body into a component in case you forgot to apply the rule 😉
Aaron.Magnin
This is the vid @TrippyLighting is referring to...
https://youtu.be/uJE-n4hyIlA
It doesn't always work, but does in some case. Its definitely worth a shot!
Cheers,
Aaron
Aaron Magnin
Technical Marketing Manager Fusion 360
TippyLightning & Aaron.Magnin:  thanks for the suggested tutorials.  I appreciate your guidance.
