Hi! Here are in my simplified scene attached two components. The components are not independent, so they are instances. My question is how to move some child component in the instance so this moved component took the same place in another component? For example, when I moved the "child-2" component in the "parent-2" it didn't make changes in the "parent-1" (child-2 position hasn't been changed here). Is there only a solution to use joints? Thanks!
