Message 1 of 9
Any methods to define distance along path of a curve or arc?
01:55 AM
Already done a bunch of hunting with no luck here, so I come to you 😄
I need to define a 3 point arc as distance along path (radius/ distance) rather than radius/ angle. I can remove the angle constraint and add a point to point but obviously that is in a straight line and doesn't give the desired result.
There are a lot of defined arcs in this project and I'm hoping there is a direct way to define these things that I am missing, though the search here and on the web doesn't look promising.
Any insights or workarounds appreciated!
