Moving a cut out created using a solid primitive
- Mute
- Permalink
- Report
Ok - I am certainly a nube to F360, but I managed to get a part modeled. This part has a semi-circular cut out across the part running in the x axis. I tried creatining a sketch on the z x face of teh part to locate a circle, then tried to extrude it through the part, but it would not let me extrude it. I ended up having to create a cylinder located at teh center point of teh circle and subtracting it. That worked, but i didn't get it exactly where it needed to be. I adjusted the dimensions on the sketch that created teh center point, but the cut out did not move. How can I move the cut out? I assume that if I had been able to extrude the circle, it would have been constrained tot he sketch, but apparently the cylinder was not constrained to the sketch for some reason? I have attached a snip of the part.
Dan
