Move/Rotate by Degrees - Is this how it should work?
Hello all,
I had a funny shaped part today and I was doing a lot of work in the "move" window.
It seems the measurements in the move window seem to be some strange mix of relative vs. absolute measurements depending on whether you are changing the last value you inputted or not.
Situation 1:
- Move x: 1in
- Change the x back to zero = the part moves back to it's original spot
This is okay - or at least, this is what I expect.
Situation 2:
- Move x: 1in
- Move y: 1in
- Go back and change x to 0 = the part doesn't move. It stays where it is (1 in off original position). You have to enter x: -1 and y:-1 in to get back to the original position. This behavior seems crazy to me. Just because I entered numbers in more than one line, it shouldn't suddenly change the move behavior.
It seems like it should be:
- Move x: 1in
- Move y: 1in
To go back to original position, enter 0 in in each.
It seems to be linked with how much text you have entered. The last number you entered, you can change, and it moves in an absolute manner (from the original position). If you enter numbers on several lines, and go back to alter them, it treats the parts current position as it's "zero point" - it begins to move relative to the position of the part.
So, in this manner, let's say a square has it's center point at 0,0
If you put x: 1 and y:1, the center point is now at 1,1
If you go back and enter x: 2 and y:2 the center point is now at 3,3
But if you are at 0,0
you put x:1, tab out or whatever and go back and change it to x: 2 (without putting in other values)the center point is at 2,0, in direct contradiction to the above method.
I created a screencast showing this.
Am I losing my mind? Am I wrong in thinking this is weird?
Thank you for any assistance.
