Move Project to another account
Message 1 of 18
OK, i tried to find a solution for this but i didn't found one.
So i am asking to be sure there isn't one.
I was working as a Student in this company on many different projects with my Student account. Now i am working in this Company and we bought a few Fusion360 licenses and got a Team Hub for our department.
How can i move the projects from my Student account to my company account?
No there is no main-assembly where every file is linked, i know about the possibility to make a f3d file from a construction. There are hundreds of single files with different versions, exported parts and norm parts.
Replies (17)
Message 2 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
The only way I know of to move projects like that is to move the project from your personal hub to your company's team hub. To do this, your student account needs to be invited to the Team Hub. Then, once invited, visit A360 and on the drop-down list for the project should be a Transfer option.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 18
It seems the 'Transfer' option has been removed...
Message 4 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can only transfer projects from a personal hub to a Team Hub. Or, from team hub to team hub. Are you invited to a Team Hub?
You can verify in A360, by clicking your name in the top-right corner and seeing what hubs you are invited to. The myhub.autodesk360.com is your personal hub.
James Youmatz
Message 5 of 18
KLickoFHQ8H
James,
I did try to Transfer the project from my personal HUB to the Team hub, but there is no transfer button.
What am I missing?
Karol
Message 6 of 18
HughesTooling
@James.Youmatz wrote:
Hi @Anonymous,
@James.Youmatz  How do you transfer between team hubs? I have 2 hubs and used invite to share a project but can't see any way to transfer the project from one hub to the other.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @HughesTooling ,
The transfer button that you were mentioning is no longer located there (next to individual projects). You can use this guide here which includes a Team Hub Transfer Wizard to move projects from Single User Storage, or an existing Fusion Team hub, to another Fusion Team Hub.
Let me know if you need anything cleared up.
James Youmatz
Message 8 of 18
HughesTooling
@James.Youmatz  Thanks but I must be doing something wrong.
This is what I see in the the account a project's been shared with.
In the owner hub I also only have the option to archive. I've even tried making the invited user Project Admin as well just a team member.
Thanks Mark
Mark Hughes
Message 9 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @HughesTooling ,
Can you walk me through your steps? Per that screenshot, that option is no longer available. You have to use the Wizard i linked to in my last post. Does that end up redirecting you at all? Can you try in an incognito Window? Just curious if there is a step I am missing - it should be a wizard with a unique dialog that walks you through moving the project.
James Youmatz
Message 10 of 18
HughesTooling
Do you mean using the "Fusion Team Hub Onboarding site" option? When I click that I only get an option to move some old junk folder I left on my old personal account to either of my team hubs but I don't see any way to transfer between the 2 hubs. I do have my team hub set as my default and I'm logged in in another tab. If I cancel out of the dialog below it takes me to my old personal hub. Do I need to transfer or delete these project first?
Mark
Mark Hughes
Message 11 of 18
James.Youmatz
Autodesk Support
Autodesk Support
Hi @HughesTooling ,
Oh... so there should be a dropdown in the upper left of the left hand column that lets you switch between Single User storage or Fusion Team. Let me check a few things on my end. Feel free to email me at james.youmatz@autodesk.com too. These can be hard to troubleshoot over the forum since theres a lot of sensitive data/names/etc.
James Youmatz
Message 12 of 18
James.Youmatz
Autodesk Support
Autodesk Support
The only thing I can think of, are you the Team Admin of the Fusion Team hub you want to transfer the project FROM?
James Youmatz
Message 13 of 18
HughesTooling
I've just set both accounts so the invited member(me) is set as Team Administrator and no difference. Tried using the onboarding site on both accounts and the only option I get is the original personal hubs on the left to transfer to either of my team hubs, no dropdown.
Really I'm only experimenting how you'd transfer a project to a customer if you've done work for them but this seems like it's been made way to difficult. What about just a simple copy project to another hub. Questions have come up a few times on the forums about moving\copying projects and folders to other hubs, surely this should be easy and something you can find within your hub.
Mark
Mark Hughes
Message 14 of 18
cheewee2000
I'm having this exact issue. I only see my single user storage account in the wizard and no transfer option from the project list.
Is there a solution on this page that I'm missing? I've tried all the steps here...
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
and
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
and
Message 15 of 18
benedikt.schleusener
same issue here. still no solution after all this time on such a simple problem?
Message 16 of 18
whittakerdw
I am going to be following this, as I had these same issues when I was trying to transfer from my student account to a new seat that my work had bought. Luckily, I was able to extend my student account for 6 months but I need to find out how to transfer all my files over without losing them. I went through and created a new hub and didn't have the transfer option when I was trying to transfer my files either.
Message 17 of 18
infoQTB9V
Did you find solution?
Message 18 of 18
whittakerdw
Yes, what I ended up having to do was add my work seat onto my school account to make all my files accessible through my work account, then I was able to transfer certain folders to my work account.
