Move object center of mass to origin?
1 REPLY 1
1931 Views, 1 Reply
Is there a way to move an object midpoint to the origin? The objects center of mass to origin,  maybe?
In 123d design this was no problem. With the "Ruler" tool you could select any point, origin or anything else, then an object and you would get the distance from the object to the selected point on all 3 axes. Min, mid and max point of the object to the point.
This is by far the tool I miss the most from 123d Design.
https://youtu.be/eDkKhWsyNvk?t=8s
Is there a way to do this in Fusion 360?
1 REPLY 1
If center of mass could be selected as the "point" in "move -> point to position" that would have worked, but it cant.
"Body to position/point" is the feature I'm looking for I guess, but, sadly, that doesn't seem to exist.
