move hole in body
move hole in body
magpiemachining
Message 1 of 11
move hole in body
magpiemachining
any way to move a hole or geometry on or to a specific location? i used the hole feature after i created the body and the tapped hole. this is probably not the way to do it but i suck at drafting on here and am trying to learn. thanx
Replies (10)
Message 2 of 11
SaeedHamza
You can double-click it from the time line and cancel the selection from the dialog box, then insert the new selection where you want the hole to be
Regards
Saeed Hamza
Message 3 of 11
SaeedHamza
About moving a geometry to a specific location, I guess the best way to do so is by using the point to point movement
Saeed Hamza
Message 4 of 11
magpiemachining
i tried that but there is no point to move to. and i cant find a place to enter a value to move to. double click on the hole will only allow to adjust the diameter
Message 5 of 11
SaeedHamza
If the hole is made using the Hole command in the create menu, it will allow you to change the selection of where the hole is
Is there a specific point that you want the hole to snap to?
Saeed Hamza
Message 6 of 11
magpiemachining
yes ther are to be 2 holes 2.0" apart in "X" and  at zero  at "Y"
Message 7 of 11
daniel_lyall
Move the timeline to before you made the hole and Put in sketch points where you wont the holes to be then move the timeline in front of the hole and edit the hole and move them to the sketch points. Then move the timeline in front of the threads and edite them if they need it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 8 of 11
SaeedHamza
Here is a screencast, hopefully it makes it clearer
Regards
Saeed Hamza
Message 9 of 11
etfrench
One easy way to move a hole feature is to:
  1. Create a sketch on the face where you want the hole.
  2. Locate a point at the new desired position (Use parameters to precisely locate it).
  3. Close the sketch.
  4. Select all of the faces in the hole (There may be several if you made a counterbored hole).
  5. In the Move/Copy dialog, select point to point icon.
  6. Select the center point of the existing hole and the new point in the sketch.
ETFrench
Message 10 of 11
daniel_lyall
Here's my idea
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 11
etfrench
To extend what @daniel_lyall shows, when you use parameter or dimensions to locate the hole, you can just edit those parameters or dimensions to move the hole.
ETFrench
