Move Folders to New Location??
tranq006
Message 1 of 8
tranq006
Hi All,
Is there really no way to move a folder to a new location (ie to a new folder) within the navigation menu?Screen Shot 2022-05-28 at 10.28.09 AM.png
Replies (7)
Message 2 of 8
jhackney1972
It the folder you are showing is at the top level of your project then NO.  You can click on the web data base icon and move the folder to another project using the web database.  In my screen capture, the folder Demo Files is at the top level of my project Beyond the Drafting Board so it cannot be move to another project using the application data panel.
John Hackney, Retired
Message 3 of 8
tranq006
Hi John,
What if you just want to move that folder into another folder in the same project. For instance moving "Demo Files" to the folder "Crawler Reconstruction"
It seems like there should be an easy way to manipulate/reorganize folders
Message 4 of 8
jhackney1972
You sure can and the Screencast will show you how.  By the way, I am using my subscription license so the video will look a bit different than my first screen post.  You can of course do the same process using a Personal License.
Message 5 of 8
stiller.design
you have more options for moving / copying files and folders in the web interface of Fusion 360:
as you can see in the web interface you have the option for moving and copying a folder
hope that helps
Message 6 of 8
tranq006
Thanks, this worked for most of my reorganizing, but I still have some folders that get an error when trying to copy or move. See Screecast. Thanks
Message 7 of 8
tranq006
Message 8 of 8
stiller.design
cool if it helped you can accept it as a solution. I am aware it doesnt work in all cases...but at least in most cases
