Move curved object to meet curve 231207
pittsallen
Message 1 of 9
pittsallen
Hello Fusion 360 forum,
Small curved object named Spring Clip Holder in
attached jpg. Working to make Spring Clip Holder
1. inner curve coincident with Fixture Side outer curve.
Have tried Align and Move. Both of these move the Spring Clip Holder Component in relation to the Fixture center point. It was conjectured that the solution is to use Align and
fit the small piece center point at distance from the Fixture center point to make the curves
coincident. But Align doesn't seem to allow for distances to be set.
Thanks.
Allen Pitts
Replies (8)
Message 2 of 9
jhackney1972
Please attach your model.
John Hackney, Retired
Message 3 of 9
TheCADWhisperer
@pittsallen
I would use Joints.
Message 4 of 9
pittsallen
Hello jhackney1972,
Model attached.
Thanks.
Allen Pitts
Message 5 of 9
jhackney1972
Your model is attached.  I found the inside radius of the Spring Clip did not match the Fixture Bottom so it would be difficult to match up the two.  I edited the radius of the Spring Clip to match the Fixture Bottom, and used a Rigid Joint to place it.  If you want to vary the angle in is attached at, simply edit the last, and only, Joint in the timeline and change the angle.
Message 6 of 9
pittsallen
Hello jhackney1972,
Sorry, attached the wrong model.
Correct model attached.
Thanks.
Allen Pitts
Message 7 of 9
jhackney1972
Same problem, the radii do not match.  Model is attached.
I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
Message 8 of 9
jhackney1972
Everything OK with your model now?  Further questions?
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
Message 9 of 9
pittsallen
Hello jhackney, theCadWhisperer and the F360 forum,
The Rigid Joint method made the difference.
Thanks to jhackney1972 for helping me find the solution.
Allen Pitts
