Move cube to diagonal
hpekristiansen
hpekristiansen
Starting with a unit cube, how do I Move it so that the long diagonals align with the axis?
Starting with a straight cube:
-and ending up with a rotated cube (here only an approximation):
Just entering "45" into "X Angle", "Y Angle" and "Z Angle" does not work as they are applied one at a time.
If it can not be done with Move, I am also open for other suggestions involving Align, or Joints. I need both the straight cube and an component copy that is angled, so constructing the angled cube directly is not an option for me.
g-andresen
If we knew what you wanted to achieve in the end, we could give better hints.
> picture, handsketch ...
günther
hpekristiansen
I do not understand. I have included picture of the desired result in OP. Should I explain better what I mean by "long diagonals" ? -or by "aligning them along the axis"? My goal is nothing more than this: Obtain a straight cube and a copy that is "diagonal" rotated.
KristianLaholm
Move 1 Rotate "45 deg" around Z-axis (blue)
Move 2 Rotate "90-atan(1/sqrt(2))" around X-axis (red)
If I understand the orientation in you image correctly.
hpekristiansen
Thank you. The trick is to do multiple rotations and I also missed that I could actually select the X/Y/Z axis and not just rotate in reference to the once rotated cube.
