Move/copy component to allign with other component
Theoforus
Theoforus
I would like to move the bottom part up to the top of the vertical part so that the upper face of the moved part are colinear with the upper face of the vertical component. How can that be done?
Accepted solutions (3)
Theoforus
I found one solution, but maybe someone has got a better one.
I made a point on each body/component and choose move - point to point.Skjermbilde 2020-05-07 13.43.02.png
Theoforus
The align tool is probably the best thing to use
jodom4
Hey reidhardr,
This forum is for discussions about Fusion 360's collaboration tools. I'm moving this post to the Design Document Validate forum where it'll be more likely to be useful to others. Glad you figured it out!
-Jonathan
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
laughingcreek
the primary problem with both of those solutions is they won't be parametric.  you'll have to do it again if you make changes to your sketch dims.
here is a screen cast with 2 methods, one using pattern, and one using joints.  either one of these will update if you change your sketch values.
https://knowledge.autodesk.com/community/screencast/3a2bd1d8-ba85-46a4-b96f-4952be74f339
