Move Copied Assembly Bug
eltron247
eltron247
So I stumbled upon this bug today. After copying a component from one file into another using "Paste New" the new component refuses to be moved.
When the initial move command that appears will allow you to place it where ever. It will stay there too, however, if you then "Compute All" Fusion promptly moves it back to the original location. This happens whether I ctrl-b or call it from the menu. It seems to continue indefinitely as I try to move it. This happens with any function of "Move," rotate, translate, etc.
I have no errors or warnings in my timeline before or after the bug happens.
I've attached a link to the screencast to demonstrate the two ways, listed above, that this happens.
Josh
Beyondforce
Hi @eltron247,
I can see the link!
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Beyondforce
Sorry, I ment to say, that I CANNOT see the link! 🙂
Ben Korez
| YouTube
