Move Component Bug
Move Component Bug
Move Component Bug
After today's update, the latest move/copy command no longer captures vertex/edge/face of other component as before, when I specify a axis and then move a component.01.pngThis is very troublesome when I try to fit a component perfectly to the surface of another component in a certain position.
Please check and help to solve this issue, thank you.
daniel_lyall
They changed the way the move command works have a look in the blog keqing song did a write up about the update
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
I have read it, but the problem still exists, I still did not find a way to solve it.
Thank you all the same : )
I re-registered an account and reinstalled fusion 360, still does not work. Haha, it drives me crazy.
daniel_lyall
You have to use the Align command it's under modify
Daniel Lyall
The Big Boss
Mach3 User
