Move Bodies To Other Components
StellarFusion
Message 1 of 10
StellarFusion
I have followed the standard by creating separate components, then bodies within each component.  However, for some reason after the last update, I'm not able to move bodies to different components.  New bodies that are created default under the project rather than the component I'm working on.  Before the update, I could move bodies as I pleased.
Has anyone else experienced this or know how to resolve?
Replies (9)
Message 2 of 10
davebYYPCU
If the new bodies go under the project, you may not be activating the component when revisiting a file, Fusion defaults to the top component.  (Been caught myself)
As for moving them - depends on what has been done before finding the need to move them
with out the file, it's a guess,
move the (sketches / construction etc that the) body is created with to the appropriate Component, the body will follow.
Might help...
Message 3 of 10
StellarFusion
So if you have to move the associated scetches along with the bodies, they may be hard to figure out.  Do you really need the scetches once the body is built out?  Can they be deleted without effecting the model?
Message 4 of 10
TrippyLighting
No, with the timeline enabled you cannot delete the sketches without negatively affecting the rest of your model.
Message 5 of 10
StellarFusion
Is there a way to know which sketch is directly associated with a body?  I have some pretty random ones in my model as this is a learning process for me.
Thanks!
Message 6 of 10
lichtzeichenanlage
  • Right-Click the body and select Edit Profile Sketch. This downside is, that this only works if you know where the sketch was located initially.
  • Hover over the sketch in the browser or the timeline and it will be shown in the workspace. Than you  might know what body belongs to it.
Message 7 of 10
StellarFusion
Thanks... I'll try your suggestions
Message 8 of 10
lichtzeichenanlage
I've forgotten the most obvious one:
  • Name your stuff! 😉
Message 9 of 10
StellarFusion
Good point to remember. Thx
Message 10 of 10
You can drag to bodies into the new component "bodies" folder - drag to the top level folder and it will add them at the bottom of the bodies list
