Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Move an SVG import
3 REPLIES 3
Nickduino
3506 Views, 3 Replies
Move an SVG import
Silly question again...
I've imported and SVG and extruded it (or its projection or something, another thread got me lost). Now I wish I could move it but don't see how:
Thanks for the help.
3 REPLIES 3
BrianEkins
in reply to: Nickduino
I tried to create a Screencast to demonstrate what I was successful with but for some reason Screencast is currently failing to start for me.  I'll try to describe it along with the picture below.  It's helpful if the sketch only contains the SVG data or if the SVG curves are away from any other sketch entities so that they're easy to select without getting other curves too.
Here's a quick way to determine if what the steps were successful and you'll be able to move the result.  Just try moving one of the curves from the SVG import.  Initially, you can't.  Perform these steps to allow them to be moved.
  1. Drag the mouse to window select all of the curves that were created by the SVG import.
  2. Right-click on one of the curves to display the context menu and choose the "Fix/UnFix" command, as shown below.
  3. Try dragging a single curve now.  If you can drag a single curve, the "Move" command should work and allow you to move all of them at once.  I had some weird behavior if I accidentally got another sketch curve in the selection when I was trying to "UnFix" the curves so if it doesn't work the first time, try it again being careful what you select.
Brian Ekins
laughingcreek
The first line in the move dialog box is for the type of entity you want to move.  it's set to body in your screen cast.  If you want to move sketch objects, then you will need to change that to "sketch"
If you are trying to move the sketch, it might help to turn the visibility of the body off, so the sketch is easier to select.
Nickduino
in reply to: BrianEkins
BrianEkins> Yes, thanks!
laughingcreek> I Wasn't trying to move the whole sketch, only the svg import. But making a sketch containing only an svg import might be a smart thing to do.
