Mould from design?
Mould from design?
Mould from design?
I have designed a part to be made in carbon fibre.
To make a CAM file for a female mould from this design can I just flip it over set the tool path up on the inside. I've tried this but it won't let me delete the bottom face so it see's it as a solid and tries to cut around it instead of inside.
A rectangular box with chamfer on the long edges represents my part.
Sorted
Used shell function and problem solved.
JamieGilchrist
you can also try the combine and select the keep tool. build a block to represent your mold insert or base and combine using your part, then split the block to make your mold halves. here is an example of this. http://a360.co/1B7ooyW this is by no means fully detailed, but shows the basic idea, and feel free to download the file if you like.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
