Motion study
Motion study
Motion study
I have a screjack assembly ,I create a motion study to clarify it's function for the students in early semester of their study,
However I found it revolve and translate very quickly although the speed pointer at the minimum
I want to know how to decrease speed
.ism and .ipt files could be uploaded if needed
JDMather
You have posted in the Fusion 360 forum.
The Autodesk Inventor forum is over here.
Which program are you using to do this Motion Study (the files you list are Inventor file types).
Can you attach your *.f3d files here?
I am sorry it is a mistake , I create this screwjack using Fusion 360 , I shall attach *.f3d
hello Sir
 I am sorry that I am new to Fusion 360, I tried to find the .F3d files but I cannot, Pls if you don't mind tell me how and where i can find them
Many Thanks
JDMather
Select File>Export
Hello sir
Thanks for your advise but I follow your steps I found some options (step .....) but .f3d not found
What to do ?
Best regards JDMather
Hello Sir
      Find attached screw jack assembly in .F3c because it has x-ref and when I try to export it in .F3d format I receive an error message  , many thanks
