Motion study observations
3 REPLIES 3
PaulMunford
1187 Views, 3 Replies
Creating motion studies is fun!
It would be great if the study could be saved, or remembered. At the moment once you click 'OK' all your hard work is lost and must be done again!
Oh - and how do I stop the floor going up and down?
Paul
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
3 REPLIES 3
haughec
in reply to: PaulMunford
Hi Paul,
We you select OK from the Motion Study dialog, you should see a Motion Study folder appear in your browser which contains your newly created motion study.  You can edit the motion study from there.
We've received similar feedback regarding the moving ground plane, and plan to address it in a future release.
Charles Haughey
Fusion 360 User Experience Architect
PaulMunford
in reply to: haughec
Got it! Thanks Charles 😄
lure23
If the bottom moving is still a problem - just place a teeny tiny box or something lower than where your model moves. It will anchor the coordinate system.
You can probably also make it transparent so it doesn't catch the eye even by accident.
Asko Kauppi
IT guy into Cleantech.
