Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Motion link
2 REPLIES 2
bmaurerHKABW
268 Views, 2 Replies
Motion link
Can anyone help me with this issue?   Trying to figure out how to open and close this blast gate with a lever.
https://a360.co/3M5MDfH
Tags (3)
2 REPLIES 2
jhackney1972
in reply to: bmaurerHKABW
You have a lot of other issues in this model.  First, you do not have any component Grounded.  Second, you have numerous missing Joints.  Third, you do not need a Motion Link between the lever and the blast gate, this should be a physical connection using Joints.  I have attached your model with my interpretation of such a link, there are others.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
mufuo
The attached video will be enough for you to perform the relevant process. Good luck in your work. Video was prepared by Manoj Kumar.
Mustafa Furkan Özel
Project - R&D Manager
LinkedIn
