Motion Link only shows one component moving
david.svoboda7Z5KQ
david.svoboda7Z5KQ
I am making a simply belt pulley reduction drive train and the drive pulley joint and driven pulley joint both work fine and show rotation.  When I make a motion link with both pulleys, the animation only shows one of the joints rotating.  What did I do wrong?
davebYYPCU
No timeline. Nothing to diagnose.
Nothing grounded.
The gear ratio is 1:1, unlikely to be real life.
Might help....
mufuo
As @davebYYPCU said, many things are missing. If you watch this video (Belt Drive (pt 2) Motion Link - Day 76 of 100 Autodesk Fusion 360 Journey - YouTube) with a simple example, something may change.
Mustafa Furkan Özel
Project - R&D Manager
LinkedIn
david.svoboda7Z5KQ
The gear ratio is 14:36 then, 14:36.  But I havent created rigid joints yet to make that all work, still stuck on the motion link.  Ill watch the video posted in another comment.   Thanks for the reply!
david.svoboda7Z5KQ
I will watch, thanks!
davebYYPCU
With the ratio plugged in and the large gear axle grounded I expect the Motion Link to operate correctly.  The joint icon was turning for both gears, but you can not see the larger gear axle turning.
Might help…..
david.svoboda7Z5KQ
@mufuo So the only thing I did differently was to ground the shafts that the pulleys rotate on.  Then it worked!  Thanks again!
