motion equation
motion equation
scacpiacenza
motion equation
scacpiacenza
hi
I am new with fusion
is it possible to write motion equations in the ANIMATION or in the ANIMATE JOINT?
thanks
Stefano
SaeedHamza
You can create parameters and equations to use as value inputs for the joints when created, or you can set the joint limit by using the same parameters.
That being said, the animation of a joint is considered a movement, meaning it won't capture the parameters changes when changed from the parameters menu, but one way to get the "animate joint" to follow the new parameters is after changing the parameters used in the joint motion limit, you can use the "Compute All" in the edit menu to recompute the limits to the new values, and when animating the joint, you'll notice that it follows the new values.
But keep in mind that if at the moment of creating the joint, you use the parameters, changing them even while recomputing won't capture the new values.
Saeed Hamza
TheCADWhisperer
@scacpiacenza
I would use Autodesk Inventor Professional for this.
