Most Efficient
Most Efficient
Most Efficient
(newb still learning the program)
Hello.
I am making a tray for board game tiles. The compartments should all be the same size with a 2 mm wall on sides and base. How can I cut out the walls most efficiently? The blue lines on the left side show roughly where I would like the cut out. I need it for the front and back both. So you can you your fingers to get a tile off the stack.
1. What is a good way to center the cutout needed? Measurement tools or whatnot.
2. What is best way to make the cutout?
Did I clarify it enough?
Thank you in advance.
JDMather
Are you dimensioning your sketches?
File>Export and then Attach your *.f3d file here.
etfrench
1. Constraints and Dimensions.
2. Extrude/Cut.
You may want to go through the learning videos under the 'LEARN & SUPPORT' tab.
ETFrench
