More issues with the Insert SVG command in current version
tombushey
tombushey
I was happy to learn that the SVG import command had been enhanced in the new update, but unfortunately it isn't working as well as it did in previous versions. In my case, several of profiles in the SVG are not importing correctly as shown in this screenshot. This same file imported with no issues in previous versions. Any suggestions?
FrankCao
 Hi tombushey,
Thanks for reporting this issue. Do you mean using the new update of "insert SVG" command, after insert into Fusion sketch, some curves do not generate sketch profile anymore?
If you really mean the profile recogize problem, could you please attach your svg file here or send it to weining.cao@autodesk.com for us to go on analyze this issue?
Frank
tombushey
Frank,
It is the first thing you said. Sometimes I get this error message "Warning: Some sketch curves cannot be converted to profile edges", but sometimes I don't get the error but the profiles are still not created for every sketch curve as shown in my screenshot. I will e-mail you an exampel SVG file.
