- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Trying to make a simple turned o-ring sealed end cap dome.
See:
I can't get the sketch to resolve.
IE it works right this isntant, but if you change any dimension it just blows up.
Almost everything shows as unconstrained.....
Not sure what I'm missing...
What constratings would be needed for all the sketch lines to show constrained?
If you achieve that try changing the overall diameter (ie hieght of the whole profile) from 2 to 3 in and see if the sketch blows up.
A specific question...
I have to lines that seem to share a coincident end point, yet when I change things they seem to break.
how EXACTLY do you set two lines to have a conincident end point.
I try selecting both lines and then the conincident constraint and nothing seems to happen?
Arghhhh this is frustrating.....
