Modifying a body
Modifying a body
wesley.bonafe
Message 1 of 9
Modifying a body
wesley.bonafe
I know how to do this but I have a question.  If you use the cut command when creating a body to remove a portion of an existing body.  Is the portion you removed gone?  Is it important to control the dimensions of the cut?
Replies (8)
Message 2 of 9
TrippyLighting
Can you provide some context to your questions ?
Without that specific context the answers to these questions seem self evident.
Message 3 of 9
etfrench
Inline
@wesley.bonafe wrote:
I know how to do this but I have a question.  If you use the cut command when creating a body to remove a portion of an existing body.  Is the portion you removed gone? (Yes and No)  Is it important to control the dimensions of the cut? (Yes and No)
ETFrench
Message 4 of 9
sanket223.patil
If you are cutting the body 1 , After cutting  there will 2 bodies . (body1,body2) . both gets seperated .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 5 of 9
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here that illustrates this answer?
Message 6 of 9
sanket223.patil
Attached with model .
Sanket Patil
Expert Elite
Message 7 of 9
TheCADWhisperer
OP wrote. " If you use the cut command when creating a body to remove a portion of an existing body. "
You used Split, not Cut.
Therefore I think that either additional information should have been requested from the OP (like attach file here)
or
you should have given example of your "solution" (and attached your example here).
My crystal ball says the OP was concerned about Extrude-Cut midplane going through all, should an explicit distance be given, or is it OK to simple drag through?
But then again, the OP specifically mentions Bodies.
Message 8 of 9
chrisplyler
If you use the Cut OPTION (not command) when creating a body, then yes, whatever you cut away from another body is gone.
If you use the Split Body command, then no, nothing is gone.
Message 9 of 9
wesley.bonafe
Thank you!
