Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Modify Rectangular Pattern Incrementally
3 REPLIES 3
gavin3PEHW
447 Views, 3 Replies
I have a component (a stick).  I want to create a rectangular patter of 5 of them (a row of sticks).  Each component  (stick) in the pattern needs to be a little shorter than the previous one (10% for instance).  The end result would be a row of sticks getting shorter from left to right, equally spaced.
I have created the rectangular pattern, but modifying any element modifies them all.
I manually create each component using copy/paste new but that seems counter intuitive as I may wish to change the spacing at a later stage, which would mean a lot of fiddling with the individual components.
Labels (1)
3 REPLIES 3
jhackney1972
in reply to: gavin3PEHW
You can do what you had planed originally but the only difference is you will create a sketch, in the top level of the assembly, that contains a rectangular pattern of points.  You will use these points to place you components use Rigid Joints in position.  You can then edit the individual components to the lengths you desire.  Later on you can go back to the assembly sketch and change the sketch pattern spacing as needed.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
etfrench
This thread from way back may help.
ETFrench
gavin3PEHW
in reply to: jhackney1972
Accepting this as my solution as it requires less re-work on my part and also matched my current ability with Fusion 360.  The harmonica example below may be a more elegant long-term prospect.
