Modify and smoothing a Spline.
kretallick144
Message 1 of 10
kretallick144
I have a Fit point spline i drew from a few fixed points.
I have replaced some of it with new lines and blended them in but i cannot find a way to smooth the joins into one continuous line.   Tried the Blend command but no change.
Need this as smooth as possible for machining purposes.
Replies (9)
Message 2 of 10
SaeedHamza
First, you have way too many points for a fit spline, if it was a control point spline, the more points the more the result will match you goal while maintaining a smooth curvature. I have a script that I created to recreate multiple connected splines into a single control point spline, why control points and fit? again to maintan a smooth result.
For your case, the creation of your spline as a fit point spline is symmetrical, so it shouldn't have more or less than a specific number of points (in you case 8 points), take a look at the attached picture below and notice that all angular tangent handles are symmetrical and equal, the same goes for the horizontal/vertical handles. This way, you get a symmetrical and smooth curvature comp.
The correct way to draw this is to create a circular pattern of a horizontal line so that you get a line every 45 deg intersecting with a projected line from your geometry, by this you'll have 8 points to snap to when creating your fit point spline.
Please find the .f3d file attached so that you can take a closer look.
Saeed Hamza
Message 3 of 10
kretallick144
Thankyou. I will have a play and see how it goes.
What would be the best/easiest way to modify only a part of the curve,  Eg, a section increased or decreased in diameter but still creating a smooth line.
Message 4 of 10
TrippyLighting
Quite frankly, I would start this completely from scratch. I've seen hundreds of such designs in my career spanning almost 4 decades. No engineer would ever us a spline for such a thing.
Maker sure to turn the timeline on 😉
Message 5 of 10
TheCADWhisperer
@kretallick144
What are you attempting to model?
Is this for a rotary engine or pump?
Message 6 of 10
etfrench
You can use three point circles or arcs to easily reproduce the splines.
ETFrench
Message 7 of 10
kretallick144
Yes for a Wankel engine.
I attempted to draw it using points plotted along the curve created by the rotor at the end points but in reality it isnt producing a consistent clearance.
Message 8 of 10
kretallick144
So how would you do it?
Timeline vanished when i moved it to start another version.
Message 9 of 10
TrippyLighting
I would sketch this with lines and arcs, just as @etfrench has described and just as @TheCADWhisperer will likely recommend.
Message 10 of 10
davebYYPCU
Smooth, use Tangent arc coincident connections.
Might help….
