Dimensioning tangent to wrong side
kb9ydn
Advisor Advisor
Message 1 of 8
kb9ydn
Is there a way to change which side of a circle to dimension from?  It seems to only want to pick the far side, which I pretty much never want.  ☹️
Please tell me I don't have to make construction geometry crutches.
C|
Replies (7)
Message 2 of 8
jeff_strater
Are you talking about tangent linear dimension in the sketch environment?  I ask because the image shows a radius dimension.  If you are, indeed talking about linear tangent dimensions, it should use the closest point to the selection point.  See the video.  If this is not what you are asking about, please clarify.  Thanks.
(view in My Videos)
Jeff Strater
Engineering Director
Message 3 of 8
kb9ydn
So it turns out if you include the circular edge before dimensioning it does pick the close side of the arc.  Seems a tiny bit lame but it's better than helper geometry.
C|
Message 4 of 8
kb9ydn
(view in My Videos)
@jeff_strater
Yes, I meant a linear dimension while sketching.  I hadn't clicked the line yet, which is why it was still showing a radius.  It behaves differently depending on whether the edge has been included into the sketch or not, before dimensioning.
C|
Message 5 of 8
jeff_strater
OK, thanks.  Please show a video and share the model of the behavior you are seeing.  Thanks.
Jeff Strater
Message 6 of 8
jeff_strater
I tried a simple case, and even with projected geometry, it seemed to work OK for me
(view in My Videos)
Jeff Strater
Message 7 of 8
kb9ydn
Video capture and model attached.  Thanks for looking at this!
C|
Message 8 of 8
jeff_strater
thanks for the model and the video.  Super helpful.  Easy to reproduce the behavior from those.  This is clearly a bug - it should work as you expect.  I created bug FUS-145037 for this.  Thanks for reporting it.
Jeff Strater
