Modifications related to timeline and version question
evanp4509U4JZ
evanp4509U4JZ
If I open the newest version of a project and modify a sketch is the sketch retroactively modified in older versions of the project? For example, if I open version 7 of a project and modify a sketch drawn in version 2 by using "edit sketch" in the open version 7, then close and save the project, will the sketch be modified if I open version 2 of the project or will the sketch be as it was at the save date of version 2?
jeff_strater
no, modifications to a design at version 7 will not affect earlier versions of the design.  You can always "promote" or open older versions and see them exactly as they were at the time they were saved.
Jeff Strater
Engineering Director
