modelling working factory model
hello,
i want to model a working factory which includes some different machine design models their simulation step by step (alll included in a single factory surface model).
i just wanted to know that which of the AUTODESK platforms would be best for my project.
whether fusion 360 solely will do so, or will i have to use a mix of some other products like factory suite _ fusion 360.. 3ds+fusion 360.. eetc..
promm
@Anonymous,
Based off your described workflow I would recommend the following:
  1. Inventor Factory Design - Machine design and factory layout with the ability to save factory assets.
http://www.autodesk.com/suites/factory-design-suite/included-software
  1. 3DS Max - Visually animate the process of a product moving from machine to machine.
  2. Process Analysis 360 - determine where any how many machine to use in order to maximize efficiency.
http://www.autodesk.com/suites/factory-design-suite/overview
Cheers,
Mike Prom
can ypu please specify that which individual Autodesk product will be suitable for
1. Modelling
2. Rendering
3. Assembling
4. Factory layout
5. Simulation
6. Texturing
7. Rendering
for my above discussed project.
As per your suggestion i have downloaded, installed FACTORY DESIGN SUITE ULTIMATE 2016 and have got access to the folowing products :
AutoCAD ARCHITECTURE
AutoCAD MECHANICAL
AutoCAD MEP
Autodesk VAULT BASIC
Autodesk INVENTOR PROFESSIONAL
Autodesk PROCESS ANALYSIS 360
Autodesk NAVISWORKS MANAGE
Autodesk 3DS MAX
Autodesk SHOWCASE
